- Calgary, Alberta, Canada
long saga with the Gilera head, obtained new guides, valves collets and caps, springs, then turned out the new valves were too long and the head was f***ed, sourced another head from Italy, plus a bunch more bits and bobs, mixed and matched everything, and the machinist returned to me today one completely reconditioned and useable head.
have had quite a bit of Court time recently so not had much time for the project, but free now for a few days, hoping to finish the wiring, install the head/exhaust/carb, and try and fire the bike hopefully within the next week or so. Lots of little details still to sort. Lots of little modifications required to make things fit nicely, brute force modification to the seat frame, rigging up a rear brake light trigger switch and mounting, etc., etc..
a couple of weeks ago I custom ordered a GPS speedo and matching electronic tach from SpeedHut, going to have to modify the headlight bucket a bit to fit the GPS speedo (hoping there is still enough room as I already have the big LED headlight assembly fitted), and figure out where and how to mount the electronic tach once they arrive, they are still a few weeks away, but don't need them to try and get the bike running.
Dellortoman (Cam) has been a huge help re the electrical wiring from scratch, integrating the VAPE 12 volt charging system, digital ignition, regulator rectifier, modern coil, etc with a wiring diagram for a scratch built harness for the rest of the bike. I agonize over each and every bloody wire, I hate electrickery....... Thankfully a very basic wiring harness, no turn signals, I am using really high quality components, connectors, shrink wrap on each connector, and so on.
a couple of photos taken this evening
