Robin Webster
- Silverstone
It’s the rings, pistons are Ross.What is made in Japan, Piston rings?
Ross pistons; cams n carbs we will have to wait and see. The pot of gold has been spent.Looks good- What brand of pistons are those and are you getting new cams or carbs?
That could have been simple stuff like cam timing and general quality of tune. If everything is right then the motor should run just fine.To be honest you may have been better served to get rid of it and take the hit.
Funnily enough those old 3C's still run well when they are clapped out, mine did anyway.
I swopped the engine for a 10,000 mile one from a crashed bike because it was cheaper than a rebuild and the replacement motor was a total slug in comparison.
Yes I would think that is correct but I didn't know about the sloppy cam timing back then.That could have been simple stuff like cam timing and general quality of tune. If everything is right then the motor should run just fine.
It’s 31,000 and some now so who knows but looking at the pistons I’d say they are not of 1976 vintage so was it ever a 3CE when it left Slaters?#21327 ? Previous job number? Mileage at last head off? Most Laverdas have “sat” for a while at one point in the last 45 years- mine sat in Mums shed for 30 years but I did have the foresight to oil the top end and bores when I was 19 thinking it might be a while till I get round to it…52 when I finally fired him up! If this is the yellow one, then I went to Bideford following it & it went really well in 2022. Trouble is once you start , you keep finding 50 year old problems. You’ll get there.
