Tippie
- Dr?bak, Norway
Time for a high frequency bath there Bruce. Bastard modern fuel.
This is what I achieved today
Started off as round bar
SF/C tappet adjuster locknut. You could have whipped a couple out of the SFC for sessions on the Motodd and done a quick adjustment when you put it back in so you could alternate!Where else would one find a 7mm nut on a Laverda?
Yep, M7Pretty sure the chain adjuster on the SFC is 7mm. It uses a 11mm spanner.
The internal mesh of the 4-stud housing, Marnix? Wonder why they needed to up that from the std SF M6??? Did they shear off in endurance races?!Chain adjuster nuts are M7, but the nuts of the oil filter on your SFC are M7 too.
Marnix
Not the pebble strainer Quentin.The internal mesh of the 4-stud housing, Marnix? Wonder why they needed to up that from the std SF M6??? Did they shear off in endurance races?!
I know Motodrob is somewhere out in the bush so not helpful for him at this point but for others wanting to find a supply of M7 nuts, older Citroën cars and vans used a lot of M7 threads. So should you wish to purchase M7 fasteners a cheaper source maybe your local/nearest OldTimer Citroën parts supplier.
Pretty sure it could be the 02 series of BMW cars...Pretty sure it has been mentioned here that the BMW 5 series used M7 flanged exhaust nuts??
I swapped all the M7 exhaust studs for M8 on the small valve head that became the BIG valve head on the SFQ.Pretty sure it could be the 02 series of BMW cars...Not sure if it was the exhaust manifold, but M7 was used pretty extensively on those. Who remembers the NSU air-cooled cars? These had M7 studs and bolts all over them!
