Laverda SF
My 70 750 SF was never off the road over 45 years save for a couple of melted pistons ;o)
Do you have resister spark plugs or leads? My understanding is that having no resister at all can cause interference to all sorts of stuff, but shouldn't double up on it (e.g. resister plugs and caps).Just to update everyone.
I've fitted a another duel outlet coil, TEC MP08 off of a VFR, fitted new HT leads and new non resistor spark plugs, (NGK plug caps), and it is again sparking and running on both cylinders.
Haven't tried it out on the road yet as we are having a wet spell, seemingly especially when I'm not at work, but generally if it ticks over it should be ok.
I expected that you would narrow it down to the coil. The old wives' tales about points being the better option hold no water with me. Boyer ignitions are bulletproof IMHO and will provide decades of trouble free service.Just to update everyone.
Stainless spark plug leads don't have a stainless conductor. It's just a braided stainless steel outer sleeve, like those used on braided brake lines. Its purpose is mainly to protect the wire against mechanical damage and perhaps provide some RF shielding. The conducting core of the lead is still copper or carbon.I've successfully run a few cars and bikes on copper or stainless leads with no problem.
Just to update further, tried it on a ride, still same problem, left cylinder miss firing and sooting up the plug so will have to start measuring resistance on components, have been in touch with Boyer to ask what the optimum coil set up is with these ignition, but haven't had a reply yet.
Information on the internet is contradictory, if single coils are used it seems the have to be wired inline, which is pretty much the same as a dual outlet coil.
I've 2 PVL 6 volts coils that I have never used, brought for another project, some seem to indicate that these give a better spark, but it's behind my understanding as to wether they are compatible.
I feel your pain. I have the same problem except non-fire on the right side. Replaced coil, plug wires and plug... no difference. I bought 2 new condensers thinking one might be bad. Went to replace them and guess what, they are riveted in place along with the cam wiper.Just to update further, tried it on a ride, still same problem, left cylinder miss firing and sooting up the plug so will have to start measuring resistance on components, have been in touch with Boyer to ask what the optimum coil set up is with these ignition, but haven't had a reply yet.
Information on the internet is contradictory, if single coils are used it seems they have to be wired inline, which is pretty much the same as a dual outlet coil.
I've 2 PVL 6 volts coils that I have never used, brought for another project, some seem to indicate that these give a better spark, but it's behind my understanding as to whether they are compatible.
Not sure why replacing the condensors needs to be such a big job!!I feel your pain. I have the same problem except non-fire on the right side. Replaced coil, plug wires and plug... no difference. I bought 2 new condensers thinking one might be bad. Went to replace them and guess what, they are riveted in place along with the cam wiper.
I will have to remove everything, take it to work, grind off the rivets and probably braze up the oversize holes, re-drill and then tap the holes. Then screw in the new condensers. Even then it's a crap shoot that it works and fixes my problem. I had to wait over a month to get the parts so you can say I am a bit frustrated.
If all works well, it might.....might work but I have my doubts. This bike ran fine when I bought it years ago and when I trucked it home, it never ran on two cylinders again. Luckily I own a couples of BMW's. Most reliable motorcycle on earth! The Laverda isn't a bike I would take more than walking distance from home. Just like a hot woman, nice to look at but she'll take your money and stab you in the back.
I wish I could find somebody to work on it, or to buy it. I hate the thing.
You don't have to "remove everything". Just take the points plate off and carefully drill the old rivets, they will come out easily and bolt on your news ones using appropriate size nut and bolt - 10 min job (cut to length if necessary). Put plate back on and adjust the gaps and timing.
Hard to comment on your other problem, you have an old motorcycle with simple ignition system so just a matter of going through the basics........Much like you would do with an old BMW! (although if the condition of your wiring and connectors is unknow, finding broken wires or dodgy earths can be frustrating - like any brand often depends on who has worked on the bike before)
No no no.... irrelevant in this case. Poster has points so nothing complicated about checking them!!I’m feeling a points/electronic argument about to erupt..... enter Paul.
I was up at The Pits yesterday in the car and noticed something, not pleasant. Lots of Agresive screaming, I asked what it was about and was told some idiot doing laps had come into the car park to do a ride through at speed and crashed into another bike. He wanted to leave before the cops arrived and the screaming was him being told to not leave the scene of the accident.In 7000 km since the sf2 hit the road again, i have had 1 failed coil, 1 failed condenser, 1 failed voltage regulator. All good now, nice little run up the old rd and back this morning, bella machina![]()
