Tippie
- Dr?bak, Norway
If you are fault finding, you can simply wire in your new condensers anywhere in the negative side between the points and the coil, with the body of the condenser earthed. The SF ignition is as simple as any ignition can get, and fault finding is as easy as ensuring that 12 volts goes to the correct side of each HT coil and that the points can earth out the negative side of each coil. Your contact points on the breakers must be good and the gap set. You can use jumper leads to eliminate all of the bikes wiring and most of it can be checked with a multi meter. I have seen voltage drop to the HT coil due to bad contact through the original fuse box cause SF to run on one cylinder. Are you spinning the motor over with the plugs out checking spark and there is nothing on the RHS? You can try swapping any components side to side to find the cause of the problem.I feel your pain. I have the same problem except non-fire on the right side. Replaced coil, plug wires and plug... no difference. I bought 2 new condensers thinking one might be bad. Went to replace them and guess what, they are riveted in place along with the cam wiper.
I will have to remove everything, take it to work, grind off the rivets and probably braze up the oversize holes, re-drill and then tap the holes. Then screw in the new condensers. Even then it's a crap shoot that it works and fixes my problem. I had to wait over a month to get the parts so you can say I am a bit frustrated.
If all works well, it might.....might work but I have my doubts. This bike ran fine when I bought it years ago and when I trucked it home, it never ran on two cylinders again. Luckily I own a couples of BMW's. Most reliable motorcycle on earth! The Laverda isn't a bike I would take more than walking distance from home. Just like a hot woman, nice to look at but she'll take your money and stab you in the back.
I wish I could find somebody to work on it, or to buy it. I hate the thing.
