A bunch of electrics photos today. I printed the final ignition box holder today. This first photo is how it prints with the supports which allow me to print over hangs , which are the tops of the lightening holes. I could have printed it with 20% infill, semi hollow, but I chose to go 100% infill with lightening holes. It made it stronger, lighter and I liked the aesthetics of it. This was a 23 hour print. And 45 minutes on cad.
The next photo is after the supports are pulled off, then on the scales without a clean up, it comes out at 56 grams. It needs a sand on the edges to make it a bit tidier. I’m printing a rubber cushion that the ignition box sits on inside as will for a bit of dampening. The bulk head everything mounts to is also rubber mounted.
I think it looks like it’s meant to be , where it’s mounted. I made a huge leap in the wiring today. Most cables have at least one end crimped , I will crimp the other ends at work Monday , by a massive Strack of good fortune, and with no skill involved they all just fall into place and look tidy .... beginners luck.
The last two pictures are the tray that sits under the kill switch ( old battery tray floor area). This will be filled with all the connector plugs for the ignition box , regulator and the kill switch connections. The box in the pictures is my rendering. It’s printing now, it will be done at 2300 tomorrow Sunday night. It’s a 33 hour print. And 30 minutes drawing on Cad. This print gets used as a female mould for a carbon lay up. I wanted a really strong light tray that wouldn’t crack or warp like plastic would. The recess line around the lip of the tray is the actual size of the tray , the recess marks out perfect edges when we vac bag the carbon down , so we get a nicer cut, past the recess is just extra flat area for lay up. Hopefully I will be done with this Thursday, and installing the tray/ box on Friday .
the single small green wire is only one of two wires for the dash lights, and control switches that runs forward , the other will be an earth , so it keeps the switch gear loom minuscule. The M button up front by the clip ons takes care of the rest.
I decided to not run the m button in the clip ons. The wiring will still be in the clip ons , but the M button will be in a small sealed thick walled Ali tube mounted on a bracket by the steering head.
