From a technical perspective, why does a chain wear in a way where it has loose and tight spots??
And, what is an acceptable difference/wear limit between loose and tight? Like, I set it up for say 40mm on a loose spot, and in a tight spot it's only about 20mm (with a subjective few kilos pressure with my hand), so 20mm difference.
(I do wash my chains with diesel and lube with 80/90 gearbox oil)
Regards, Greg
Regards, Greg
