In short No........if its running rich set in middle groove with your other settings, and you haven't replaced needle and emulsion tubes??Short of replacing needles and tubes, do you think there would be any advantage in changing the needle position one step?
Time to pull it apart and have a closer look at the needle config.Main jets aren't your problem Charlie
have you got the correct thickness washer under the brass seat for the float needle and are the needle jets all tight??
Laverdas seem to be reasonably un-fussy about Dellorto jetting. Just chuck a bit of fuel down the inlets and they'll run. As long as it's not way too lean it'll be OK. You only need to get fussy when you want to maximise performance and fuel economy. My jota had 140 mains in it when I bought it and it ran OK at WOT. It was a bit down on power and guzzled fuel like there was no tomorrow, but there were no noticeable flat spots and the plugs didn't foul up.Seems low on factory spec Cam? Check my factory manual.... right you are Cam, 118 for 1000 and 115 for the 1200.
Hi Chuck,
first of all, I would exchange all needles and jets, ultrasonic-clean the carbs and re-assemble them with new seals and parts. Else you are chasing the problem from an unknown state of wear of the parts.
Second, I would check if the float valves REALY seal. could easily be they don't, then you are also chasing the problem with no result
Last but not least: is it really fuel that is burned or might it be oil, please...? Not uncommon that the valve-seals on the intake side harden over time and don't seal anymore. As it is black smoke though, I suppose it's gasoline and not oil (would be more blue smoke then)
One more thing: if it happens only while accelerating hard, it could also mean that your accelerator pumps are set wrong.
Thanks John, new plugs and a plug chop are on the to-do list. Hopefully I can identify which throttle opening range and so which jet circuit is the culprit. (Btw, all 3 plugs look like the previous picture.)Here goes...more free advise, a smile here. Plug condition has a few notables, the actual threaded metal body internal wall has flaked build up of contamination, that is the coolest part of a plug as such takes a long time to build up. Ceramic nose is well contaminated, beyond a clean would proffer. New plugs, BP8ES and a 10km plug chop ( easy on the throttle, you already know large throttle effect ) would be next, ie are all three carbies, indicated by the plug chop, the same. If so that is the good news, whatever is the reason or reasons for this condition, fix one fix three.
The k/l your having is close to what factory engines consumed with gross over fueling to compensate for the one step BTZ. That was in the main ( pun intended ) idle pilot jet domain. Going out on a limb, factoring in the various suggestions from the well experienced folk, this issue you have has a lot in common with well known cold crank fuel enrichment fault(s). Mains issue am far from convinced even though it has some commonality of puffing black exhaust and high fuel consumption.
Post new plunger seals, are there witness marks on the rubber pads to indicate some degree of effective sealing. j
In my experience, replacing these can make a big difference. I would make this my next move.there are a few parts I have not yet replaced like the emulsion tubes and needles which I will get
