- Calgary, Alberta, Canada
Hi dalehi Paul,
would like to talk to you regarding the 1200, can you pm me with your contact details , thanks
Dale
just saw your post, will DM promptly.
Hi dalehi Paul,
Dale
I understand your thoughts Paul. I have had ‘ garage resident duplication’ and have adjusted the residents to a more varied selection. It makes perfect sense to me. BTW, I do not consider a 180 Laverda and a 120 Laverda to be duplication.Hi Steve
great suggestion, but way over the top for this particular project. Shipping of the forks to USA and back, the costsof rebuild in USD, etc., when I don't even know yet if and how the bike runs......, I suspect I am going to offer this Centauro for sale in the spring, I have my eye on a 2023 Moto Guzzi V100 Mandello S in green/silver, was talking to the local dealer yesterday about placing a refundable deposit for delivery in April, 2023, we'll see. Looks good in the photos and videos, but need to actually touch one and sit on one before deciding.
V100 Mandello: Roadster and Tourer Mix | Moto Guzzi EN
V100 Mandello: the bike that combines the comforts of Touring models with the character of Roadsters. Browse versions and specifications.www.motoguzzi.com
I am still pursuing a downsizing and rationalizing garage agenda, I have various of my bikes for sale, intending to reduce to maybe three bikes total....... Someone really needs to make me an offer on the 1982 Laverda 1200 TS Mirage Series 2, it is absolutely gorgeous and perfect, but i am keeping my 79 1200 and I don't need two very similar bikes......![]()
I don't do duplication either! Triplication +....I understand your thoughts Paul. I have had ‘ garage resident duplication’ and have adjusted the residents to a more varied selection. It makes perfect sense to me. BTW, I do not consider a 180 Laverda and a 120 Laverda to be duplication.
yeah, I already tried banging in imperial size, then TORX, the allan heads are now mush and the fasteners are still seized solid. Welding seems to work reasonably well, likely partially at least because of the heat. Was easier to access the frozen/seized Allan heads on the brake rotors but I expect I will be able to get these sump case bolts out one way or the other.If they are allen heads it can sometimes work by banging in a torx.
Is this ‘a thing’ with the quality of the fasteners, or had someone been in there before and tightened them up way too much?yeah, I already tried banging in imperial size, then TORX, the allan heads are now mush and the fasteners are still seized solid. Welding seems to work reasonably well, likely partially at least because of the heat. Was easier to access the frozen/seized Allan heads on the brake rotors but I expect I will be able to get these sump case bolts out one way or the other.
will be replacing with stainless fasteners.
Yes for sure. My 10 yr ownership of my new purchase 2001 V11 Sport entailed a lot of problems associated with poor engineering and lack of R&D to most everything, except the base engine itself, the pushrod 2 valve engine, which was solid as a brick. Only once did I pull the oil pan off, mainly just to have a look around, as my model had an access port for the spin on oil filter. Never had an issue with any fasteners on the base engine.I haven't had any problem with those same fasteners on my 2001 V11 but I know Big Gord had issues back in the day that he reckoned were previous owners. Lots of people wouldn't be bothered to get the wrench to access the oil filter so they dropped the pan (lots of guys were scared of doing it the easy way and having a filter come loose.). Probably a few ham fisted chaps gronched a few bikes along the way.
Jim
