henrywillms
- Canada
At my age my leak down tester makes my underwear wet....
Sounds like the voice of experience,...Tena for men. Won't stop the leak but prevents a wet seat cover.
Wet dream for the over 70s?Tena for men. Won't stop the leak but prevents a wet seat cover.
Yes, I have to confess that I did buy a leak down teaser of dubious pedigree. It was utterly useless. There was no way it was ever going to work.Hi Cam,
Most of us buy unbranded leakdown testers from "that country"
But then, there would be less fun, and what the heck. let's rebuild this oneAll I can say is most of us will never get value out of a perfect solution because we are too old. I wince at the prices of pistons etc, the money would be better spent on petrol if an acceptable resolution could be found with used parts etc.
I really agree and discussed this during my training many many years ago. Everything you point out is true. I can only vouch for the tester if it is used to convince a seller that the engine needs work, in my case it helped a lotThe problem with a pressure gauge that reads in % is that you can't test its calibration. Ok, you can hook it up to a manifold with another (trusted) gauge fitted, pump it up so the pressure on the master gauge says lets say 7 bar for example, and the leak down gauge says 85%. WTF does that mean? I'll tell you what it means - nothing. I want to know what I'm dealing with. If I want the reading of the second gauge as a percentage of the first, I can do the arithmetic myself.
I thought about "fixing" it as you did with yours, but even if I could get it to work, I wasn't convinced of its value as a diagnostic tool anyway.
A simple compression gauge tells you pretty much all you need to know, and is way simpler to use. I suppose a leak down tester might be useful to diagnose the leakage path, but simply pumping compressed air down the spark plug hole and listening at the inlet/exhaust ports or the crank breather will do that.
I don't remember what I did with my useless leak down tester. I think I recycled the pressure gauge (the one that actually reads pressure) to resurrect a tyre inflator that had a busted gauge. I haven't seen it for ages so may have chucked the rest of it out in a fit of disgust.
I am experiencing the same process , I think, I am receiving all kinds of parts, stil making an inventory until all is measured and protocolled. Still have the head to go, which seems ok, with bronze guides and well sealing valves. I am still working on the valve buckets, which look a bit mangled, I think I have found some automotive ones. pretty cheap and if the head is ok, would fit.So back somewhat towards topic (odd, I know...) @Ernestee0 where are you actually at with the bike and how is it going?
Some years back I accidentally rescued a very rough and corroded UK import 1200 that came to my place for fitting a new ignition and left a year later completely rebuilt.![]()
What vehicle would they be off?? I'd be wary of anything that critical unless you can guarantee it's a spot-on fit.I am still working on the valve buckets, which look a bit mangled, I think I have found some automotive ones. pretty cheap and if the head is ok, would fit.
