MarnixSFC
It’s great to hear that Jim had his tested and that it confirms my findings. It’s certainly reassuring.I never doubted you, Marnix !![]()
By replacing your rear hub with an aluminum one you will weigh down your rear wheel by a kilo
Forget about the dietTime to get serious about my diet then!
Don't get it. Why??Yep go to trouble to save some weight using Mg hub then fot a heavy disc to it!! Same as the SFC oil filler, light weight Mg cover then use a heavy steel filler cap!!
Well an extra kilo for piece of mind is probably worth the extra weight. Heading to perth this w/e so will have a good look at that GS1000 hub.
I thought that Larry was the only one I knew who wrecked a mag rear hub. Now hearing that he sold it because he didn’t trust it anymore brings the number back to zero.You'd have to consider that magnesium was/is an exotic material that was fitted by race engineers for any weight advantage it could offer in the very short term. It was never fitted with a view to long term durability, so I'd be very sus of it after 40 years - that's why I ended up with Larry Strung's rear SFC hub - he refused to race on it, and that was when his bike was only 15-20 years old.
Believe it or not but the SFC "heavy" rear disk is actually lighter than the later front oneYep go to trouble to save some weight using Mg hub then fot a heavy disc to it!! Same as the SFC oil filler, light weight Mg cover then use a heavy steel filler cap!!
motoddrob said:Believe it or not but the SFC "heavy" rear disk is actually lighter than the later front one
If my memory serves me well a drilled rear solid disk weights around 1.9Kg and a front one 2.2Kg.
IMG_1081 by Michael Kurtz, auf Flickr
68A00EC1-088D-4C5E-8EEE-5F2684A347CB by Michael Kurtz, auf Flickrit is because you then will still have some resources to reduce weightStill can't understand why they fitted the really heavy steel filler cap
Good point, Greg. I'd be interested to see the difference between various spoked wheel strengths; there must quite a bit of variation - hub strength, spoke triangulation flange-to-flange, spoke length and all the other parameters that make a good or bad wheel.Funnily enough, one of the first things I advise potential GS1000 racers is to avoid the spoked wheels. They seem to want the look...
They spend big dollars on a 5 inch alloy rim and a heavy duty spoke job - then wonder why their bike doesn't handle as well as one on mags...
Wheel stiffness is a wonderful aid to handling.
I am starting to see why the early GS750 spoke hubs are becoming scarce in Australasia though. You SFC owners are buying them up.
