Shorted drive transistor Cam, 3 pin device, think i used a PNP due to the quirk in the quad comparitor, see if i can scare up the hand drawn schematic, LM339 comparator, LM431 programmable Voltage reference some resistors as divider chain, and a drive transistor. The later has to carry the incandescent lamp surge current, between 6 and 10 times normal lit current, hence the driver transistor get a flogging, BD139 or BD140 is the cure.... then you will mis it not glowing...it would drive me to distraction as it is on your ride.... 3 solder joints Cam...you can do it... post you a couple of transistors, maybe a surge limit resistor in series with the output wire to the lamp.... remain at your disposal.... jIt's still on the bike John, but no longer works. Red light stays on all the time. It only worked for a few months, so I installed a voltmeter. I submit the photo below as exhibit 1. Note that at 2000rpm the system voltage is 14.3V, but the "GEN" light remains on.
One of these days I'll remove the charge light gizmo. Do you want it back to diagnose its failure mode?
