Something in you post Paul, FWIW, lean mixture burn, is at a lower temperature than the correct Stoichiometric burn, ditto over rich, its lower burn temnperature. A lean mixture does not provide adequate piston crown cooling hence the old mechanics incorrect assumption it burns "hotter".
Confirmed when i used 3 K type thermo couples on the first bend of the exhaust headers, many a moon ago. Around the 450-480C from memory, peak combustion chamber temperatures are over 600C.
Correct me if i have the blue tinge to headers aspect misunderstood. Non bluing chrome headers can be produced, its much about how the steel is electroplated. Another topic...j
