You're not going about it properly.Well Paul, To give you a quick summary of my issue with the ignition, I have an engine that starts, runs but the right exhaust is stone cold....No spark. Replaced the coil, plug wire and spark plug and still no spark and a cold pipe. I am assuming it's a condenser because I had one fail on a car of mine back in the 70's and the condenser failed when the car drove thru a dip in the road and the shock killed the condenser. The bike ran fine when I bought it and while driving home with it in the back of my truck, it must have jarred it enough to kill the condenser (I assume). So here I am and I have to put the new ones in but I need to grind off the rivets that secure them but that's an issue for tomorrow when I can take it to work where I have the facilities to do the job properly.
I am totally open to remote mounting the condensers but I have no idea on where to locate them or for that matter, how to even wire them up. I know they only have one wire but where do I connect the wire? Should I mount the condensers to an aluminum plate and go from there. I want them located in such a place I can replace them in a minute or so, assuming they are the Achilles heal to this engine. Does it matter how long the wires are and how far they are from the points? You may know by now I have no clue on the workings of an ignition system except that when it works, all is good.
I've been running my SF2 with the same condensers since 1992 and it's very likely that they were fitted by the factory in 1973.
Condensers do break down but they are not the Achilles heel of this engine which doesn't really have any.
That jolt could have done all sorts of things notably broken a wire or undone a loose connection.
You need to check, with a voltmeter or a 12 volt bulb, positive feed to the coils, positive feed to the points and the condenser from the coils, it's a common feed.
Are the plug caps receiving volts. You can swap plug leads from side to side and see if your problem changes sides or not.
It's a very simple system plus from coil to condenser and points. Static point and condenser are both earthed, condenser via it's body. The opening of the circuit when the points open causes the coil secondary winding to discharge via the plug which is earthed.
No doubt somebody better than me with electrics will come along and say that I'm talking balls. But that's it basically. Stay simple and test everything.
Forget your fixation on condensers.
And as has been mentioned, running an old mechanical contraption requires some basic skills. They all give problems at some time or other, even old BMWs.
