Dellortoman
- Tasmania, Australia
From TDC, intake valve to open in first 180 degrees, second 180 degrees both valves closed, third 180 degrees both valves closed, final stroke exhaust valve opens last 180 degrees, from 540 - 720 degrees.
Yes, you definitely sound confused. Inlet should open some time before TDC, not in the first 180° after TDC. The first event after TDC on the power stroke is the exhaust valve opening.
If you start on the power stroke: Plug fires a bit before TDC, then nothing happens with the valves until a bit before BDC when the exhaust valve opens. It all depends on your cam profile, but a typical figure might be around 45° BBDC or 135° ATDC. As the cycle continues past BDC and the piston rises, it gets most of the way to the top when the inlet valve opens, perhaps around 20° BTDC. Once you're past TDC, the exhaust valve closes. Let's say this happens at 20° ATDC. That bit between inlet opening and exhaust closing is the overlap. Normally, the middle of the overlap period is roughly centred around TDC on the non-spark, or "breathing" stroke. Or perhaps with a bit more of the overlap on the ATDC side.
It's a single camshaft, so the relationship between inlet and exhaust timing is fixed. Looking at the photo of the camshaft here: https://www.laverdaforum.com/xf/attachments/61114/
the lobes on the camshaft will be separated by about 120° plus or minus around 20. It's that 120° "V" between the lobes on the camshaft where the overlap happens.
A good starting point would be to set the piston at TDC and then engage the cam gear so both tappets have about the same lift on the non-spark stroke. If the tooth pitch doesn't let you get it centred on TDC, retard the cam until the next available tooth (move the cam gear opposite to the direction of rotation). That'll bias the overlap after TDC. Your camshaft gear looks like it has about 36 teeth. If that's the case, then shifting one tooth either way will change the timing by 20° at the crank. That's quite a big jump, so hopefully the correct spot will make itself obvious.
I don't recall how the ignition timing is arranged so you might have to assemble the points to figure out which stroke is which.
Having done all of that, check the exhaust opening and inlet closing positions. They should be roughly the same distance either side of BDC (around 40-60°?) but not on the same stroke - there's no overlap there.
All of the above figures are just examples. Your camshaft maybe wildly different. To get an idea of what your cams are doing, you could have a close look at the camshaft itself. Measure the offset between exhaust and inlet cam lobes. Once it's in the engine with the cam followers installed, use a degree wheel to get an idea of the duration that each valve is open. You can stick all those figures in a spreadsheet and play around with the numbers until they look something like the numbers you've measured. Then make an educated guess as to where TDC fits into that table of numbers.
I've prepared a little spreadsheet for you. Just play around with the numbers in column 2 until they resemble what your cam actually does.
I've included a calculation of the cam lobe offset that you can check against your camshaft.
