Andy
- Auckland, roughly
As seen in the video below, and probably seen by most here... I can see wear to both output shaft and sprocket (sprocket has 13,000km).
I assume that any play will accelerate wear. Is there anything I can/should do to reduce play apart from replace the sprocket?
I found THIS THREAD (which I couldn't resurrect) and it has some good suggestions: reverse the sprocket (chamfer to the outside), shop around for a tighter fitting sprocket, loctite, and even welding.
This must be an ongoing problem with all sorts of machines, is there a "standard solution"?
View attachment IMG_2724.mov
