GregT
- Christchurch NZ
Yes, agreed. But re sprockets, I've been retoothing vintage/classic sprockets for years. Where a new original is unobtainable. Pull the right size/pitch sprocket off the shelf and bore it to fit the machined down original. Then weld. And harden.Highly unlikely the sprocket would be soft, Greg. It's the splines that seem to get hammered. No easy fix on them without a case split and some specialised engineering work.
But it has been surprising to me how many off the shelf replacement sprockets are soft. I expect to have to soften them prior to machining but probably 20% don't need it.
These are reputable brand aftermarket front sprockets too.
Always worth a quick and dirty hardness test before fitting a new front sprocket.
