Find myself in agreement with Mr Piranha regarding the carbs .......... If it was possible to find another friendly triple owner who would let the carbs be tried out on his bike ( not exactly a difficult or time consuming task just to swap them over ) , then that would be one possible cause of the problem eliminated ( or not ) , at a stroke ............ Easier said than done if you don`t know a willing Laverda owning participant , ( or lucky enough to have a spare bike ) .........
Having said that ...... If the bike was starting / running / revving cleanly before the problems arose , then I would have thought it`s unlikely the carbs are at fault ........ It seems to me unlikely that the carbs would " go off " suddenly , if they were performing perfectly well beforehand ...... Unless some major internal fuel circuit flow / filter problem had suddenly occurred ... ( maybe ) ........
Having said that ( again ) ........ I don`t know the bikes maintenance history ...... or if it had been in regular use before the problems arose ...... or how many times the carbs had been off and inspected , and whether that was before or after the problems started ....... or who fitted and set up the ignition system ........ and so on , etc., etc., .............
If I had the fore sight in the past , I would have obtained as many Bosch CDI stator plates , rotors , black boxes , " dead mouse " ignition coils , and so on , as possible ...... when they were easily obtainable ...... giving me three or four spare CDI ignition systems ......... Simple , reliable , easily repairable ways of providing sparks in the right place at the right time ........
Thus equipped , if faced with the problems Robin is now experiencing ............. ( and provided the carbs had been 100 % eliminated as a trouble scource ) ............. I would then remove the Ignitech system ...... throw it as far away as possible ........ and then fit the simple , straightforward , reliable Bosch CDI system ..... ( yes , reliable ....... mine did 150,000 miles on the original black box , then another 50,000 miles with a replacement black box ..... plus two or three replacement " dead mouse " coils , and a replacement stator plate , as pick up wiring was getting a bit iffy ..... obtained on an excellent exchange basis from Alan Bell .... ) .....
When I was eventually unable to obtain service parts for the Bosch CDI , I replaced it with the Witt DMC system , retaining the CDI rotor / stator plate , which was easy to fit and worked perfectly .
However , I realise that doesn`t help Robin much in his current predicament ............. All I can say is stick with it , maybe try to enlist the help of someone in the UK who knows ...... ( someone with Laverda background / knowledge , I believe one or two still exist ............ Not someone who usually works on 1993 Ford Fiestas .... ) ....... eventually it will be sorted ........ After all , it`s only a motorcycle we are dealing with here , not the SpaceX programme ............
