So Here we are again!
I rolled out the RGS yesterday morning, fired up with full choke and it started quickly but sounded lumpy, so feeling the pipes it turned out this time it was the centre pot that was cold ( last time it was the right one, some of you may recall ) so I pulled out the plug tested it, no spark, cleaned it up and tested it against the casing, still no spark. I took the plug cap off the HT lead it came off very easily and the hole in the end of the HT lead left by the screw looked very black. So I cut 5mm of the end of the lead and screwed the cap back on, stuck it back on the plug and tested it again, nice fat spark, problem solved, you'd think. Put it back in and pushed the button. Not a sausage apart from a couple of HUGE backfires.
So. Pulled out all three plugs and checked them all the plugs have what I would call healthy sparks but I gave all three a quick clean up anyway.
I have touched nothing else at all: but it won't fire, just gives me a huge occasional backfire, Voltage is 12.8, Starter motor is spinning beatifully, as I say all plugs are sparking.
Anyone got any suggestions as to why fixing one plug would bugger up the whole bike.
I thought I might have simply flooded it but I also thought spinning it few times whilst all three plugs were out being tested, fuel tap off, would have allowed that to dissipate, but tell me if I'm wrong. Along with any other suggestions.
