Rob
- Midlands, UK
I've no idea how you tested them, or what device you used but those values are unusual. Did you measure with the pickups disconnected from the rest of the ignition system? The resistance of each isolated pickup should be as I previously stated, around 60 ohms.I tested the pick-ups for resistance today and they all came in at 0.21 or 0.216 depending which scale you set but the point is they are all the same and no shorts.
You could go one step further and check that there is a very small voltage appearing on each pair of pickup wires when you crank the engine - it's been ages since I worked on a bike with original pickups but it's a small value, maybe 2-4 volts depending on your meter's sensitivity.
No - if the plug doesn't spark then there's probably too small a pulse to fire the strobe.would an electonic timing gun, of the type which uses a sensor that clips round the HT lead, flash or not.
It really is worth fitting brand new plugs - and make sure you earth them when cranking the engine. I'm not sure how an Ignitech handles unearthed plugs - but it's a good way of knackering BTZ and DMC units.
I'd strongly recommend you don't reprogramme the Ignitech - given the bike ran previously the setup must be good. You are looking for a wiring fault.
I'd echo Steve's point about reversed connections on one trigger. Clearly things have developed since the original fault. It's very difficult to solder adequately on to the old wiring. Corrosion/verdigris on the conductor strands can easily result in a dry joint. Looking at your photo of the triggers it seems that you haven't touched the wiring at that end? Ordinarily I would expect to find flaking insulation there too.
