Miguel,
Rest assured, it is NOT 05B (do you really think we hadn't checked that?). Pitch and width are not the only things defining a chain, especially roller/bush dimensions play a MAJOR role. 05B, 06B/2/3 etc are standardised chains. You can regard the C107HC chain as custom-made.
Next problem will be tooth count, ideally it should be uneven/even, ie 15/30T, to spread chain and tooth wear evenly. When using even/even, ie 14/28T, the chain links will run on the same teeth over and over. Guess this can be neglected to some degree, no great milages will be spooled off and having a readily available chain, it can be replaced at shorter intervals.
Like I stated, nothing is as easy as it first seems.
