a14rgs
- Wiltshire, UK
I'd still be swapping the taps to a known 'good' pair to eliminate or confirm the issue - my previous offer refers
Test the flow it’s easy to do with a measuring jug from the kitchenI'd still be swapping the taps to a known 'good' pair to eliminate or confirm the issue - my previous offer refers![]()
Yes, will do, tank is in paint at the moment, base colour this morning, 2K clear this afternoon. Hope for it to be ready Wednesday.Test the flow it’s easy to do with a measuring jug from the kitchendo both taps and reserve
I bought a pair of taps a while back that looked the same ... they were way too small and sit unused on the shelf.Are they definitely Laverda taps? Reason I ask is they look the same as Lambretta taps and they don’t flow enough for a Lambretta, just wondering if they have been changed for taps that look the same but are cheaply scooter ones..
It’s the gearbox sprocket oil seal. A previous owner had been at it with silicone. All back together now but didn’t have fresh oil at home so will get some in the morning.You'd need a hell of a tailwind to get "an oily foot" from "the oil seal behind the gearbox sprocket", Robin.
Check, first, for oil below the starter motor.
If that's clean, remove the generator cover.
If there's oil in there, it's the crankshaft seal behind the ignition pickups.
Water washing is a waste of time not to mention unnecessary. Fill it with water. The water will force any remaining gas out and water doesn't explode. then prop the tank up so where you need to weld is at the highest point Sometimes people go on about the stupidity of having water near electricity!! water is nowhere near as good a conductor as metal and that's what you're welding/brazing ( that's if you're MIG, TIG welding ) though it will take heat out of the weld area, but I'd have gas brazed it myself.The hole must be welded up, and any search on this forum regarding tank liners should scare you off. Even ones that do not break up in the tank create a nightmare for future crash damage.
If welding a fuel tank use nature as your helper. Set the tank in a warm ventilated place, upside down and let the heavier than air fuel vapours pour out. In Australia the sun did the job in a few hours, in Norway we have sat in near a heater over night. You can see the fumes pouring out and after a while there is not even a whiff of petrol. Test as suggested. Water washing even for days with running water has had tanks explode injuring/killing people.
Sorry fella, but you weren’t there!I'm sure people didn't mean get on it and thrash the arse off it without doing basic safety checks.
So it's a nail then? Maybe it can be rescued as you say by the right person but demand seems to have disappeared.
Advertise it and see what happens, maybe you can cut your losses.
NopeYou still have to do your own due diligence. It isn't metallic red now by any chance is it?
