.im a photos sort of person, or drawings sort of person. My brain looses a lot or plain just doesn’t understand words sometimes, they just don’t draw a clear picture in my head.All the big post classic racebikes I build have full floating rear calipers. 10mm fine thread heim joints with around 15mm of thread engagement stand up to a vigorous rider backing a big bike into corners, If your rider can manipulate the clutch or you have a back torque limiting clutch you get no chatter and the wheel stays in contact with the ground over the typically rough street circuits we have here.I make a front anchor point which is in double shear - a bracket each side of the front heim joint. I really don't want to calculate the load on the torque arm with slicks and a heavy bike - but empirically i can say I've not had one break.
I'd offer cone nuts as an alternative fastening for Astralites. High temp version of nylocs with a metal insert rather than plastic. Bit more secure than plastic too.
Not much difference between 316 and 304 stainless as far as strength goes. The main difference is that 316 has slightly better corrosion resistance so tends to be the choice for marine environments. They're both what's known as austenitic stainless steel, and both have an ultimate tensile strength (UTS) of around 600MPa, which is comparable to mild steel.What would the tensile strength of 316 stainless be?
Thanks CamNot much difference between 316 and 304 stainless as far as strength goes. The main difference is that 316 has slightly better corrosion resistance so tends to be the choice for marine environments. They're both what's known as austenitic stainless steel, and both have an ultimate tensile strength (UTS) of around 600MPa, which is comparable to mild steel.
As far as bolts are concerned, I'd consider stainless bolts (either 304 or 316) as roughly equivalent to grade 4.6 steel bolts. OK for general stuff like the universal M6 bolts that hold engine covers on, but I wouldn't use them where high strength is required. You'll propbably get away with it most of the time, but for critical applications like brake caliper fixings, I wouldn't replace grade 8.8 bolts with stainless.
Actually, it's not the UTS that's the design criteria, it's the yeild strength. "Yeild" is the stress point at which a piece of steel will permanently deform (ie. beyond its elastic limit). UTS is the point at which it actually breaks apart. The yeild strength is considerably less than the UTS.
Im a freak of natureWell sorted Todd.
BTW, mate, your left hand is tiny, well groomed nails though![]()
Hi CamIf it was my bike, I'd have simply welded a lug onto the underside of the swing arm and bolted the torque arm to that.
Or, used the existing caliper carrier stop system and make an upside-down carrier mounting bracket for an under-slung caliper.
Or, simpler still, leave the caliper where the fastory put it - above the swing arm.
What's the reason for mounting the caliper below the swing arm anyway? I can think of a few reasons NOT to mount a caliper under the swing arm, but no reasons in favour of it. So to me it seems a lot of work for no benefit, but maybe I'm missing something.
They come in pretty handy in the shop too, halyards and sheets I have built into boxes for shipping around the world !While I'm not qualified to do an analysis on it, the offset front bracket i don't like. If it's got to be like that, make the offset so that it's hard up against the top edge of the frame bracket. It'll move as it's shown IMO.
All my big bikes use 10mm fasteners both ends of the torque arm. 8mm is IMO, a tad light.
You're lucky having a helper. I have to use blocks of wood....
